Author Topic: nocooler's firechicken thread  (Read 304831 times)
« Reply #570 on: January 03 2019, 08:24:43 PM »
Tap it and screw another one in.
« Reply #571 on: January 04 2019, 08:34:57 AM »
I’ve been busy working on the car. I’ll have some updates this weekend  :rock:
I will say I broke the nipple off the damn map sensor for the boast controller, I need to see if I can replace the map or I can just run it open loop based using duty cycle.
Plastic?
« Reply #572 on: January 04 2019, 09:18:57 AM »
Plastic and to small to tap.
« Reply #573 on: January 04 2019, 12:06:14 PM »
Use a magnifying glass haha. I would think the problem would be the plastic chips from threading but some trans gel or vaseline on the tap to collect the chips. And a threaded barb, I'm sure someone makes a plastic one or brass. Just have to find the tap that fits the threads. What is it like 3/16" or something? Even an eighth or sixteenth. Might not be worth the hassle of collecting up the tap and threaded barb.
Or a new unit,there's always that.
Something like this.
https://www.mscdirect.com/product/details/01795541
https://www.fastenal.com/products/details/0326796
I bought a three bar like this.
https://m.ebay.com/itm/NEW-GM-STYLE-3BAR-3-BAR-MAP-Sensor-For-Electromotive-Motec-Megasquirt-With-Plug-/122053187412?_mwBanner=1&_rdt=1
There are more expensive ones too.
Cuz I'm a cheap a$$ and like to have new tools.
« Last Edit: January 04 2019, 01:15:04 PM by TexasT »
« Reply #574 on: January 04 2019, 03:14:51 PM »
https://www.ebay.com/itm/Pressure-sensor-MPXHZ6400A-MPXHZ6400AC6U-/291969170541
That’s what it looks like Rich it’s about 3/8” square total.
Hole is .110 id - I might have a tap but I think it’s cheaper to replace it.
« Reply #575 on: January 04 2019, 03:17:21 PM »
I read the blue print wrong od is .110-.130 - the hole is half that size.
« Reply #576 on: January 04 2019, 10:44:13 PM »
$14 from Digikey and for $8 shipping you get it next day
« Reply #577 on: January 05 2019, 03:49:24 PM »
Made a trip to Ohio today, traded my 6speed setup for a legit th400 setup.
The deal included well built th400 (billet internals, rvmb, brake, aftermarket bell housing, nice aluminum deep pan), ptc 9.5 converter, sfi flex plate, b&m pro ratchet shifter, dump valve (aids spooling), umi cross member, dual cooler setup with a fan, driveshaft, and a leash bumpbox.
The setup came out of a 1000rwhp 4th gen camaro - stock bottom end deal. I’m going to try the converter and see how it works, but it might need to go back for a restall.
I need to decide on rear gears think 3.50 maybe a 3.25.
Offline wmsonta
  • Turbo Street Stock
  • PSI: -1
« Reply #579 on: January 05 2019, 04:06:19 PM »
pics
« Reply #580 on: January 05 2019, 04:06:59 PM »
another
« Reply #581 on: January 05 2019, 04:08:38 PM »
Thanks wmsonta - already been playing with numbers.
3.50 puts me where I want to be rpm/mph wise thru the traps - 3.25 would be better on the street.
Offline wmsonta
  • PSI: -1
« Reply #582 on: January 05 2019, 04:28:10 PM »
3.50  - 3.25
Do not forget stall with a non L/U converter. If the converter supplier won't make a recommendation, you will have to guess. I guess 7% for 5500 stall or higher, for example. IMO, the difference in one ratio (3.25-3.5) is hundreds of a sec in a quarter, unless the car needs 60 ft help. Converters are not an exact science. I have known people who have bought 4 or 5 to get right. Expensive education.
Agai n, my opinions.
Expensive appearing transmission.
« Reply #583 on: January 05 2019, 06:31:17 PM »
Jeremy...call Dusty. He'll take all the guess work out of it for you for stall and rear gears. I cut my teeth with this guy about convertors on the other board when he was posting. Learned from him how to get a 'tight' convertor to 'flash' higher off the line and how a 'tighter' convertor will MPH better.
Here he is setting a world record...https://www.youtube.com/watch?v=brR4BwzujhI
Oh...and break out your reading glasses and get the numbers off the convertor for him. I might be able to break it down here.
« Reply #584 on: January 05 2019, 07:06:20 PM »
I’ll look at it again Monday, it’s a 20 blade stator. I was planning on calling ptc, Brad can you pm me Dusty’s number. My gut says run it, get data and restall as needed.
