Author Topic: nocooler's firechicken thread  (Read 900699 times)
0 Members and 19 Guests are viewing this topic.
« Reply #420 on: August 15 2017, 10:56:43 AM »
Says unavailable Mike
So I checked on the rocker trunnions after everyone has started a panic on ls1notech - and the one I checked looked fine. I'm going to run them another season.
« Reply #421 on: August 15 2017, 11:11:36 AM »
Nevermind it came up - I'm waiting on fuel lines. The rest of the stuff I'm working on an hour here and hour there. I can't push myself to hard or I'll pay for it.
« Reply #422 on: August 15 2017, 01:31:47 PM »
Jeremy...put yourself in a retirement mindset like I have. There's always tomorrow.
« Reply #423 on: August 15 2017, 04:46:09 PM »
Brad - I pretty much have to do that. I set a 1.5hr timer on my phone and once it goes off I'm done. It seems to be working out good, I make notable progress and it keeps my pain to a tolerable level. I can push through and work longer but that means I'm not going to be able to doing anything for the next few days, and It's just not worth it. It's nice to have a project to tinker on
« Reply #424 on: August 19 2017, 03:30:08 PM »
I'll put up a video next week, I need to watch the last one and figure out what I've done since then.
Here is a teaser for now.
« Reply #425 on: August 22 2017, 12:30:17 PM »
« Reply #426 on: August 22 2017, 01:20:14 PM »
I really like using these: http://www.ebay.com/itm/2x-10mm-3-8-Fuel-Non-Return-One-Way-Check-Valve-Petrol-Diesel-Marine-Aluminum-/152667444060?hash=item238bb0535c:g:UmkAAOSwD~xZlb4p&vxp=mtr
I have them on the TBSS' catch can set up.  The way I set it up it is always either pulling vacuum from the filter (compressor inlet) or the valve cover.
« Reply #427 on: August 22 2017, 01:44:16 PM »
Keep at it Jeremy! Lookin' good!
« Reply #428 on: August 22 2017, 01:47:01 PM »
http://m.ebay.com/itm/Air-Ride-Suspension-Chrome-Check-Valve-3-8-npt-Female-to-3-8-npt-Male-Brass-/122259102859?nav=SEARCH
I looked at those Mike, but ended up with the one I linked. My vacuum block was supposed to be 3/8 npt, but it's -8an oring - so plans had to change
« Reply #429 on: August 25 2017, 04:51:13 PM »
Oooh... fancy!
« Reply #430 on: August 28 2017, 11:30:05 AM »
My brother got married on Saturday. Daycare is closed this week and my wife took vacation, it's going to be a long week. The boys are a handful to say the least!
« Reply #431 on: August 31 2017, 03:08:25 PM »
Fans are wired - just need to wire the relay triggers
Flex fuel sensor is wired and the pressure transducer is wired to the egr input on the pcm.
List is getting shorter.
« Reply #432 on: August 31 2017, 08:16:07 PM »
Keep at 'er!
« Reply #433 on: September 01 2017, 05:18:06 PM »
Got a bunch of small stuff done today. More like pain in the ass, had the console out and the carpet up. Move the wbo2 sensor lead from a rubber plugged hole in the floor to the shifter hole. While I did that I ran the vacuum/boost lines for the boost gauge and controller and the solenoid wire for the boost controller.
I got the interior back together, just need to decide where the boost controller is going to live.
« Reply #434 on: September 01 2017, 10:55:18 PM »
Jeremy...you woulda cracked the 9's without even trying tonite with the air here. Keep it up...you're almost there.
