Author Topic: nocooler's firechicken thread  (Read 918180 times)
0 Members and 15 Guests are viewing this topic.
« Reply #405 on: August 02 2017, 09:08:03 PM »
Im seriously considering this- http://www.hybrid-power.com/_p/prd1/2896339861/product/new-hdi-electronic-boost-controller-ebc-r-evo cheap electronic closed loop controller. I've seen lots of positive reviews. I was going to use a mac valve with a compressor regulator but this should fit the bill @140 usd
« Reply #406 on: August 03 2017, 02:43:24 PM »
Too bad you cannot set a curve to aid with spool.
« Reply #407 on: August 03 2017, 07:56:34 PM »
Yeah I'd like full control like an eboost2, ams500, boost leash, but this will be a start. I doubt it's going to have very much lag.
« Reply #408 on: August 06 2017, 01:44:08 PM »
https://ldperformance.co.uk/product/electronic-boost-controller/
found that one for $169 on ebay - I might go that route instead. I like the overboost protection and the ability wet the start boost aiding in spool up...
« Reply #409 on: August 07 2017, 08:23:59 PM »
I'll try to make a video in the couple days. I've been making some decent progress on the little stuff. Other than a belt, oil, power steering fluid, brake fluid, and coolant - I should have everything I need, ordered and on the way.
I'm have I feeling I need to check out the rocker trunion bearings, and replace them with a bushing style.
Exhaust is going to be a pain in the ass. I'll need to borrow dads welder, as mine is pretty much worthless. I ended up with a mess on IAT sensor bung, so it got ground and epoxied.
« Reply #410 on: August 08 2017, 02:01:52 PM »
« Reply #411 on: August 08 2017, 09:22:01 PM »
Damn Jeremy...looks like all that stuff grew there. Once again...well thot out. Keep the vids comin'.
« Reply #412 on: August 08 2017, 09:31:42 PM »
Yes, go Straub.
« Reply #413 on: August 10 2017, 10:09:16 PM »
I was going to go cheap china crap to save some of the budget, then decided they all looked like crap and I wanted a nice gauge.
« Reply #414 on: August 10 2017, 11:38:23 PM »
I have that exact same guage in my limited. Love the auto meters
« Reply #415 on: August 11 2017, 12:16:39 PM »
Now you gotta make those vroom vroom and turbo-whistle noises.
« Reply #416 on: August 11 2017, 04:32:23 PM »
I thought I had the bumper cover fitting, but I spent some time today tweaking it. While it fits nice the v-band for the box is very close. I'm going to play with the piping a little and see if I can gain some clearance, or need to keep going at the bumper cover. I need to test the new gear I put in the headlamp gearbox - plastic gear on metal, wtf was GM thinking? Ah well its got an aluminum gear in it now. Of course I only did the drivers side so, the passenger one will probably fail now.
And yes, I was making 2-step noises, and some turbo noises yesterday.
« Reply #417 on: August 11 2017, 06:36:01 PM »
I'm a sucker for the burgundy/wine colour.
« Reply #418 on: August 14 2017, 07:38:16 PM »
Nose is on.
Have some wiring, fuel pump/lines, boost controller/gauge, vacuum lines, new plugs, find a belt, and then I should be close to flashing a 2bar tune to this thing and lighting it off.
« Reply #419 on: August 15 2017, 10:34:33 AM »
