Author Topic: nocooler's firechicken thread  (Read 921658 times)
« Reply #1335 on: July 17 2022, 11:15:30 AM »
Mother trucker - it's the front pump seal. There is a ledge above the pan rail that fills up and then splashes over. I put my pick in there and found a nice puddle up there.
« Reply #1336 on: July 18 2022, 01:04:26 AM »
Well, the bright side is that  you can stop messing with the pan.
« Reply #1337 on: July 18 2022, 10:39:21 AM »
After running 9s I don't mind wading through some shit. That sweet taste of victory makes the mundane not suck as bad. Had it not performed so well my outlook probably wouldn't be the same.
« Reply #1338 on: August 05 2022, 11:40:36 AM »
Figures I'd get this Envoy Denali XL back together and it has an exhaust leak. I wanted to fix it but my brother just wants to drive it at this point and see how it does. Pretty sure the manifold on the passenger side probably needs surfaced. The cam we stuck in it was real close to the ls6/ls2 cam so I had him copy a TBSS fuel/timing maps and it runs really good.
My wife and I went to a concert last Friday - and it was amazing. Auburn Michigan - population sub-2000 people, and there were 10000 people in the park for the concert. The first picture is behind us, and then a shot to show where we were located. I was really apprehensive about being in a crowd, as I really don't need drunk assholes running into me - but everyone was respectful and cool.
It was Chase Matthew, Struggle Jennings, and Jelly Roll. They had to pull the plug on Jelly at midnight, an hour past curfew.
« Reply #1339 on: August 05 2022, 01:24:25 PM »
Beautiful night for it!
« Reply #1340 on: August 05 2022, 02:21:19 PM »
Noice!  I haven't been to an outdoor concert in a long time.
« Reply #1341 on: August 07 2022, 10:55:52 AM »
I helped a good friend yesterday work on his wife’s 2015 equinox. I changed both cam vvt solenoids, front crank seal, and replaced the serpentine belt. Took nearly an hour, and $150 worth of parts - dealer estimate was $1000!!!!!
« Reply #1342 on: August 07 2022, 11:32:48 AM »
The dealer always wins in the end.
The dealer would probably have to pay for a technician to come in from the district office to do the work...
« Reply #1343 on: August 07 2022, 03:09:08 PM »
Trans is out and it looks like it was one of the pump/bell housing bolts leaking. Looks like they used a thread locker not a sealant like the directions show. I really don’t want to pull the pump but I know this mother f’er will leak if I dont
« Reply #1344 on: August 13 2022, 10:06:04 PM »
It's back together. It needs a few more quarts of trans fluid and I'm hoping it's done leaking.
I was surprised to see that the transmission did have some really nice-looking pieces of hardware inside when I pulled the pump out.
« Reply #1345 on: August 14 2022, 01:47:27 PM »
...and it's back out
« Reply #1346 on: August 14 2022, 02:42:14 PM »
Well, damn
« Reply #1347 on: August 15 2022, 10:28:13 AM »
Unfortunately, I don't think I'm the first person to mess with this leak. One of the lower pump holes needs the threads repaired, so I've got to pull the pump and see what my options are. I don't know if there is enough meat to properly Helicoil it. I've heard some use aviation sealer others use Devcon aluminum epoxy as it's strong enough to be drilled/tapped, and I've seen others weld it up and re-tap.
I've got to get it apart and get a game plan.
« Reply #1348 on: August 15 2022, 11:17:51 AM »
from what I read, most epoxy fixes will not hold any torque beyond lightly snug.
« Reply #1349 on: August 15 2022, 11:38:30 AM »
It's got some nice parts in it :O
Yeah, I'm not sure about using epoxy either Steve. The devcon aluminum is supposed to be a whole other animal, but it's $100 a pound. I'm going to look at helicoil and timesert options.
