I think I mentioned the problem that I was having with the ptc converter lacking clearance to the flexplate on my son's wagon. Given that the torqueflite that we installed did not have a mounting boss for the column shifter linkage and it had been well abused in the past, we pulled it out and installed one that came from a guy up in Indiana. We still had too little clearance. I talked to ptc and sent the converter back and they shaved 0.040" off the ears... It came back and it was still closer than I wanted and the converter seemed to be suddenly tight on the input shaft of the transmission. I talked to them again and they made a new unit and sent it to me during the Christmas holiday week. Talk about service!
In the meantime, I got another flexplate just to cover the bases and discovered it has 0.100" less offset than the hd unit I was using. Between that and the new converter, I suddenly had 0.125" clearance which I was aiming for. I am not sure how much problem the first converter had and how much was with the flexplate but that part is finally all good. When he was here during spring break, we did not get as much done as we wanted to but he has three kids and a wife that always wants to go eat when she is awake. Makes it difficult to get the usual 15 hours in LOL
But my new Daytona Super Jack worked like a charm and I was able to set the car off the blocks to jack stands and then all the way to the floor. I was able to control the drop down to an almost imperceptible rate and it was a piece of cake.
Still have a bunch of wiring to do, and I could knock it out pretty fast if motivated but I want him to do it so he will know how it all works...or is supposed to work.
I have had the Challenger parked outside and I decided I should crank it up and let it run a bit...nothing happened when I turned the key to start. After some troubleshootin g, I decided the starter relay was not working but after hitting it a few times, it came to life and fired right up. It needs a good cleaning under the hood as rust is accumulated from the moisture not getting burned off things.
I ordered two relays, one for the Challenger and one for his car. I guess they are not so reliable after 50 years?
I probably should have pulled the 526 out of the Challenger and put it in his wagon but I am tired of pulling stuff, go figure.
