EGR keep or delete
Topic: EGR keep or delete (Read 3233 times)
Shimy87
PSI: 2
EGR keep or delete
October 02 2014, 10:32:57 AM »
While I'm working on this, whats the scoop. TT chip dosent use it, can I make a block off plate or should i just keep it where it is?
Also want to clean up some things. I dont use the wastegate soliniod, if I unplug that will it throw a code? Same question on the EGR soliniod. If i can eliminate them and just hide the plugs it would clean up the look but I dont want it to screw something up.
Thanks!!
Re: EGR keep or delete
October 02 2014, 10:49:58 AM »
Be sure there is zero leak when you remove the egr. I usually put a thin smear of high temp rtv around the edges before clamping the block off plate down.
No problem removing the solenoids. Code is disabled in the chip
earlbrown
PSI: 6
October 02 2014, 04:50:52 PM »
If you're good with a drill motor, it's not a bad idea to drill and tap a couple of small screws between the ports to help with the clamping. It's just too much mechanical leverage on that one bolt down low to expect 100% seal 100% of the time.
tb3
PSI: 2
October 03 2014, 12:26:10 PM »
I never understood why the egr is usually programmed to be inop on aftermarket chips.
If it doesn't rob horsepower, and saves fuel at idle, what's the harm?
SuperSix
Administrator
PSI: 234
October 03 2014, 02:07:55 PM »
It's ugly, and there's a lot more places for potential vacuum leaks.
Reply #5 on:
October 03 2014, 03:18:21 PM »
It is not operative at idle, only during cruise. Makes it easier to manipulate fueling at part throttle if you get it out of the way
tb3
PSI: 2
Reply #6 on:
October 03 2014, 09:52:03 PM »
Oh yeah! Cruise. .
that's what I meant.....lol!
makes sense to me then.
Thanks Steve!
and yes it is ugly.
I left the brass plug in mine from the earl brown mod and put the egr back on to dummy it for stock appearing
TURBOPOWERED68
Turbo Street Modified
PSI: 1
Reply #7 on:
October 12 2014, 09:07:06 AM »
i have seen the egr hole drilled and plugged. it looked pretty good too.
Thats the way i will go if i ever pull my intake manifold off
earlbrown
PSI: 6
Reply #8 on:
October 13 2014, 03:15:19 AM »
That's my intake. To install a pipe plug, you really need a milling machine to make that square hole round.
EGR keep or delete
