Author Topic: Vacuum brakes  (Read 11463 times)
Vacuum brakes
« on: September 12 2014, 09:23:43 AM »
Good morning gents.  I meant to ask this question a while ago. My brakes were switched over to vacuum brakes years back.  Sometimes I notice after I hit the gas really good and then immediately tap the brake, the brake pedal is hard for a second before going back soft and allowing to stop properly. What do i need to fix this problem? Thanks
Offline PacecarTA
  • im not a newbie
Re: Vacuum brakes
« Reply #1 on: September 12 2014, 10:29:48 AM »
replace the check valve at front of booster
i run a second checkvalve  inline that i get from imports in the junk yards
87 GnX'd
87 GN TTop..stock as can b
Re: Vacuum brakes
« Reply #2 on: September 12 2014, 10:55:42 AM »
check valve is that round piece that goes in between two hoses? Thanks for the response Paul. Can I pick one up anywhere?
Re: Vacuum brakes
« Reply #3 on: September 12 2014, 11:31:10 AM »
Normally, the check valve is the plastic piece that plugs onto the grommet on the booster...Hose from plenum connects to it.
Paul is saying that he added a second check valve in the line to that one.  There is also a filter in the line on some cars which is a bigger can than an inline check valve
And, yes, any parts store will have one...often on the HELP rack
Re: Vacuum brakes
« Reply #4 on: September 12 2014, 02:26:08 PM »
thanks for the help guys.
Re: Vacuum brakes
« Reply #5 on: September 12 2014, 02:27:19 PM »
I finally fixed my hood.  I changed the oil last weekend.  Also installed that SLIC that was laying around.  Car seems to run great.  Loves the cooler weather for sure.  I still have the boost turned down pretty low.
Re: Vacuum brakes
« Reply #6 on: September 12 2014, 03:57:38 PM »
while you are on a roll, you can come help me work on cars...they all need something
Re: Vacuum brakes
« Reply #7 on: September 15 2014, 08:17:34 AM »
Now as lazy as i am Steve, that'd be a miracle.  I would be interested in seeing that motor you got installed in your other car. That thing is gonna be a monster.
