Double check your cam sensor. I put mine in at 3:30 in the morning and accidently put the cap on 360' out. Car started fine when cold put really hesitated when warm, similar to what you described, pulled a lot of amps on the starter.
Quote from: Forzfed on September 11 2014, 07:29:03 PMDouble check your cam sensor. I put mine in at 3:30 in the morning and accidently put the cap on 360' out. Car started fine when cold put really hesitated when warm, similar to what you described, pulled a lot of amps on the starter.360 degrees out, you say?
ok it now starts....BUT>........ it wont idle or keep running starts an dies unless i keep on the throttle...if i unplug the maf it runs longer but still stalls. ideas?
thanks bum but I'm running a stock maf still. i did swap it it out for a now one i had laying around with no change.i did the iac reset thing no change, but does the iac number on the scan master continuously change or should it be a certain number an stay there?this one was jumping 10 30 25 15 etc?i did hold the throttle till the car was fully warm 160+ an it idled on its own but i noticed my wide band would swing from 0 to maxed out an back again as well as the vac gauge 10 15 20 0 etcI'm starting to think theres a vac leak but i don't hear any kind of air movement noise/>
