Author Topic: is power logger screen display still only one size?  (Read 4786 times)
Offline tb3
« on: August 24 2014, 10:54:22 AM »
I want my power logger screen display on my new laptop to be a little bigger to match my screen size.
Is there a way to do this?
thanks
Re: is power logger screen display still only one size?
« Reply #1 on: August 24 2014, 11:18:16 AM »
I think they were hard coded. IIRC Bob has done some special resized versions, ask him.
« Reply #2 on: August 24 2014, 11:20:06 AM »
You could go to a non native screen resolution and see how fuzzy it becomes, its a tradeoff. I miss CRTs.
« Reply #3 on: August 24 2014, 02:51:37 PM »
I have one of the first batch of PL's that came out...and it's slightly larger than the screen. I put the gauge panel up...and hit monitor to "see" it working.
Offline PacecarTA
  • im not a newbie
« Reply #4 on: August 24 2014, 07:30:07 PM »
thanks
try changing the screen size ,  otherwise drop turbobob a message , he had altered a version for smaller netbooks so the screen fit as it was too large
« Last Edit: August 24 2014, 07:38:33 PM by PacecarTA »
87 GnX'd
87 GN TTop..stock as can b
Offline tb3
« Reply #5 on: August 26 2014, 12:08:38 AM »
I tried the screen resolution thing on my new hp laptop and that didn't work.
in the meantime, I have other issues.  does anybody have a link to the latest drivers that will work for windows 8.1?  I have just done the advanced startup thing that disables the "driver signature enforcement".
I was not able to connect to my gn the other day with my new laptop as it kept giving me a com port error.  I have been able figure it out with older operating systems, but windows 8.1 is new to me.
thanks to all of you for replys   :cheers:
« Reply #6 on: August 26 2014, 01:56:52 AM »
I recommend killing 8.1 with fire and ''downgrading'' to something better.
Offline PacecarTA
  • im not a newbie
« Reply #7 on: August 26 2014, 03:16:17 PM »
^^^  i agree ,
i run XFI and it doesnt play nice on 8 either
 picked up a couple cheap used netbooks of ebay for under a hundred with win 7 and no issues
87 GnX'd
« Reply #8 on: August 26 2014, 03:29:30 PM »
Try another com port. Mine pulls the same stunt...as well as a couple of other guys that have PL up here.
