Author Topic: 4.1 bolt torque  (Read 2250 times)
Offline shmed
4.1 bolt torque
« on: August 15 2014, 11:51:40 AM »
does anyone know if the torque values for the 4.1 with arp studs are the same as with the 3.8?
Re: 4.1 bolt torque
« Reply #1 on: August 15 2014, 02:06:58 PM »
What studs are you talking about, head?  They are the same.
Offline shmed
Re: 4.1 bolt torque
« Reply #2 on: August 15 2014, 02:31:32 PM »
yes   studs for head to block
Re: 4.1 bolt torque
« Reply #3 on: August 17 2014, 03:52:15 PM »
yes, you go with ARPs torque specs not Buick specs
