I run the solid shafts on my engines.
Quote from: Scoobum on August 02 2014, 09:54:54 PMI run the solid shafts on my engines.Are they a solid chunk of steel with no hole thru the middle to lighten the weight...or, are they what certain vendors call solid but are still hollow....same as the old hd units that we used to be able to buy, which is what TA sells, I believe.I suspect the rocker shaft caps will make a stock one last a long time
ok my 4.1 is breaking the rocker shafts at the bolt holes yes weak point question is years back someone was selling stronger shafts I have a set on my gn don't remember who if anyone sells them anymore an ideas thanks
