Author Topic: Rear Gear Oil Recommendation?  (Read 3333 times)
« on: July 28 2014, 10:38:25 PM »
New rear axles arrived. Rear gear oil recommendation s? Auburn Pro Series posi...if that makes a difference...a nd car sees track duty only.
Re: Rear Gear Oil Recommendation?
« Reply #1 on: July 29 2014, 03:29:16 AM »
I like 'whatever is on sale' for a good price when it comes to picking out my gear oil.
Offline The Radius Kid
« Reply #2 on: July 29 2014, 03:51:43 AM »
It's awfully tough to beat a good dino oil for that situation.
« Reply #3 on: July 29 2014, 08:56:54 AM »
Here... I Googled it for you:
http://www.moserengineering.com/moser/faq/
Quote
AUBURN
What kind of oil and additive should be used with an Auburn Performance Differential? It is important when installing an Auburn High Performance, Pro Series or ECTEDŽ LOCKER that a high quality non-synthetic 80W90 GL-5 gear oil be used. Treat the oil with Auburn Gear, GM or Ford friction additive.
Three ounces of additive treats one quart of oil.
Friction additive part numbers:
Auburn Gear: 504102
GM:1052358        Ford: C8A219B546A
« Reply #4 on: July 29 2014, 02:49:31 PM »
Thanks so much gents.
« Reply #5 on: July 29 2014, 11:32:48 PM »
No whales were harmed in the making of this additive?
« Reply #6 on: July 31 2014, 12:37:24 AM »
It's sperm whale oil, so I guess it depends on the whale's outlook while extracting said sperm.
Offline tb3
« Reply #7 on: August 08 2014, 09:00:00 PM »
whale sperm n my rear-end?
I'm gonna leave this one alone :O
