Author Topic: Spooling help  (Read 18709 times)
Spooling help
« Reply #45 on: August 03 2014, 03:22:22 PM »
Maybe an pre turbo exhaust leak with the added back pressure?
Re: Spooling help
« Reply #46 on: August 03 2014, 03:59:06 PM »
brad, that would make the boost higher
Re: Spooling help
« Reply #47 on: August 03 2014, 06:12:02 PM »
Damn I'm brain dead.
Re: Spooling help
« Reply #48 on: August 03 2014, 07:37:26 PM »
Wait til you're old
Re: Spooling help
« Reply #49 on: August 03 2014, 07:40:35 PM »
Made a thicker shim for boost controller, have It maxed out. Have actuator arm set at 1\8 inch pull to place over pin. 22lbs :( ran out of time but going to set arm  to 1\4 inch to pin and see if that gets me to 25????
Re: Spooling help
« Reply #50 on: August 03 2014, 08:41:23 PM »
As said above,  exhaust leak,?  With it running,  do you feel a leak under the turbo where it bolts to the up pipe?
Re: Spooling help
« Reply #51 on: August 03 2014, 09:08:01 PM »
No apparent leaks. I can pour sea foam into the vacuum line that runs the brake booster to make smoke to find any leaks if I remember correctly?
Re: Spooling help
« Reply #52 on: August 03 2014, 09:34:42 PM »
Worth a try
Re: Spooling help
« Reply #53 on: August 04 2014, 05:32:54 PM »
Been thinking and the symptoms car has are like the puck isnt sealing correctly. Will be checking that along with exhaust leak test.
Spooling help
« Reply #54 on: August 04 2014, 06:05:01 PM »
Yes sir make sure it's lined up and the weld holding the puck is not preventing it from sealing. There is a thread with pics on the other board.
Re: Spooling help
« Reply #55 on: August 04 2014, 09:18:23 PM »
Puck lined up perfectly, no exhaust leaks with seafoam test, no vacuum line leaks. This thing should be boosting like crazy??
Re: Spooling help
« Reply #56 on: August 04 2014, 09:27:27 PM »
Once upon a time...there was a guy up here in Canada. He bought a GN...and for the longest time he couldn't figure out why it took forever to spool. He one day took it upon himself to slide under the car to verify what convertor was installed. Instead of it being a D5...it had 7's stamped on it...which was a convertor out of a Monte Carlo SS with a 200...which stalled much lower.
Re: Spooling help
« Reply #57 on: August 04 2014, 10:01:39 PM »
At this point im satisfied with the rate of spool. What I need is to get it to push more than 22-23 lbs, thats all I can get?? I want 25-26 but with rjc boost controller shimed and completely turned in and hd actuator arm a tick over 1/8 inch pull to get on pin it wont pull more than 22-23 lbs even at the top of 3rd gear
Re: Spooling help
« Reply #58 on: August 05 2014, 10:38:06 AM »
As I said, hd actuator should give 18-28 psi.  If you are using a stock downpipe with a stock exhaust housing, there is a chance that the factory puck is not quite large enuf to cover the waste gate hole, or the hole is slightly off center.  I believe RJC racing sells a larger puck that can be installed on the factory housing..
Re: Spooling help
« Reply #59 on: August 05 2014, 11:23:32 AM »
Stock housing, 3 inch downpipe, I checked that puck idea last night. put some red chalk line powder on puck and put housing back on and clicked it closed a few times. Perfectly centered over hole with about 1/8 inch ring of red dust all the way around so that seeems spot on.
Tonight I'm going to set actuator arm to 1/4 inch pull to get on pin and see if that helps?
