Author Topic: It's Alive!  (Read 3401 times)
It's Alive!
« on: July 18 2014, 10:17:08 PM »
New engine fired up today without a hitch. SM numbers were bang on...and she runs as smooth as silk.
Re: It's Alive!
« Reply #1 on: July 18 2014, 10:28:32 PM »
Lovin that!! Mine seems to create a new problem every time I twist the key :icon_eyes:
Re: It's Alive!
« Reply #2 on: July 18 2014, 11:08:46 PM »
keep it that way!  :D
Re: It's Alive!
« Reply #3 on: July 18 2014, 11:17:44 PM »
Gonna try. Been pretty lucky over the years. Two cracked cylinders...an d one piston pin came loose and scored up a cylinder. Only time I lost a pair of head gaskets was when the vacuum hose from the port to the actuator collapsed. Run mine tuner style. I log every run and go over it in the trailer between runs.
Re: It's Alive!
« Reply #4 on: July 18 2014, 11:54:57 PM »
Glad for ya!  Still piecing parts together for my engine build and saving money for the machine shop. It is nice to have a running turbo Buick in the meanwhile.... But she sometimes pushes my engine build further to the right...
It's Alive!
« Reply #5 on: July 19 2014, 03:55:35 AM »
Get out there and cane it!
Mobile larrym
Re: It's Alive!
« Reply #6 on: July 19 2014, 08:43:27 AM »
Mobile larrym
Ran it in yesterday. Oil and filter change...and put da' boost to 'er!
It's Alive!
« Reply #7 on: July 19 2014, 02:29:43 PM »
That's how to seat the rings :)
Mobile larrym
Re: It's Alive!
« Reply #8 on: July 19 2014, 08:35:04 PM »
Modern rings may be seated before you get it to the street
