Author Topic: SM question  (Read 3018 times)
SM question
« on: July 18 2014, 06:07:08 PM »
Doing some tuning today working on launch mostly. Letting off top of 2nd. The SM records O2 but shows no mph. It does show mph if you scroll to it so it is reading it. Still reading over 800 for O2's down low and chip is turned down to 113 setting in 1st, 125 setting over all is showing 792 O2s top of 3rd
Ran out of time to continue today
Also set first gear timing to131 setting
Re: SM question
« Reply #1 on: July 18 2014, 09:50:51 PM »
Hold the recall button to show timing retard and o2 millivolts. While pushing the recall button, press the button on the left side at the same time and SC will display the mph of the lowest o2 recorded.
Re: SM question
« Reply #2 on: July 18 2014, 10:25:47 PM »
Yes I know, it shows the O2 but shows 000 on the mph ????
Offline TURBOPOWERED68
  • David
Re: SM question
« Reply #3 on: July 22 2014, 09:07:28 AM »
VSS is bad??
Re: SM question
« Reply #4 on: July 22 2014, 12:56:22 PM »
But it does show mph when you scroll to it on the sm ???
Re: SM question
« Reply #5 on: July 22 2014, 01:40:14 PM »
Full throttle run?
Re: SM question
« Reply #6 on: July 22 2014, 03:50:25 PM »
yes, but not thru 3rd, let off in middle of 3rd. The weird thing is it would record the O'2's but not give me a MPH. I thought maybe VSS also so I checked the SM mph setting and it is working fine.
Re: SM question
« Reply #7 on: July 22 2014, 07:23:21 PM »
I believe the tps has to read above 3.0 volts for more than one second..that is why I asked
