starter question
Topic: starter question (Read 2437 times)
Shimy87
PSI: 2
starter question
July 18 2014, 05:21:34 PM »
Another stupid question from me. I have a brand new battery in car. Alt is showing 14 volts on sm when car is running. It barely turns over fast enough to start? I thought starters either worked or didnt. Is the starter going bad and weak or is this something else? Thanks!!!
Re: starter question
July 18 2014, 05:34:58 PM »
one sign of a tired starter....
Scoobum
July 18 2014, 10:19:35 PM »
While yer under there check to make sure the heat shield is there. If it hasn't got one...get one.
Shimy87
PSI: 2
July 18 2014, 10:26:47 PM »
Will do
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
July 19 2014, 01:39:10 PM »
How old are the cables? Might be corroded up under that sheathing. It was amazing what a custom built welding cable did for my big block suburban.
Forzfed
PSI: 5
Boost n00b
Reply #5 on:
July 19 2014, 05:14:17 PM »
The actual connectors can lose their conductivity as well. I remember on my old top post battery in my Toyota, I kept wire brushing the posts and connectors then smearing on some dielectric grease, still nothing. Then a mechanic at work was telling me of a phenomenon especially on top posts where they can lose their conductivity from the battery gases and other crap. Sure enough put new ends on and never had a problem starting again. Weird or what?
starter question
