Author Topic: poly motor mount  (Read 3095 times)
poly motor mount
« on: July 16 2014, 04:41:35 PM »
looking to replace drivers side with one of these. Where can i find one. Only one i found so far is $129.....seems kinda crazy as a stocker is like $8
Re: poly motor mount
« Reply #1 on: July 16 2014, 05:19:53 PM »
« Reply #2 on: July 16 2014, 06:42:52 PM »
Personally, I would suggest a stock replacement mount unless they don't make them anymore.  You don't have enuf traction to cause the engine to severely try to rotate and break the stock mount quickly...
« Reply #3 on: July 16 2014, 08:11:53 PM »
I agree that the poly mounts are way to high, so I made my own. :O :cheers:
« Reply #4 on: July 16 2014, 09:49:43 PM »
HRPartNStuff here.  Well worth the money.
« Reply #5 on: July 16 2014, 10:17:51 PM »
X 2
Offline tb3
« Reply #6 on: July 18 2014, 07:59:54 AM »
I went with hr figuring I wouldn't ever have to bother with motor mounts again for the life of the car.
I'd be curious to know if anyone's ever had one break
