Author Topic: Weird wiring issue, MAP related  (Read 5173 times)
Re: Weird wiring issue, MAP related
« Reply #15 on: July 16 2014, 04:39:33 PM »
The SM actually said that was at 21 MPH??
« Reply #16 on: July 16 2014, 04:57:56 PM »
Believe that was the leanest it saw. You have to watch it while you are getting on it.  Start by making sure the FP is correct
« Reply #17 on: July 16 2014, 06:48:47 PM »
We could be a lot more helpful if we had a PL file.
« Reply #18 on: July 16 2014, 06:57:42 PM »
for sure
« Reply #19 on: July 17 2014, 05:06:22 PM »
Sorry, dont got the PL  :icon_confused:  Only had time to make one test run last night. Still real rich down low. Also kinda sluggish on the shift again, probably gonna pull the tv cable out one notch and see if that cures it.
