Author Topic: Actuator?  (Read 7376 times)
Re: Actuator?
« Reply #15 on: July 10 2014, 12:54:22 AM »
TPS is steady now. Looks like you found your problem with the flaky voltage.
Re: Actuator?
« Reply #16 on: July 10 2014, 11:48:49 AM »
If I followed this correctly- you might want to now log the TPS 5v for a run. You changed the 5v source but what was going on with the old 5V source?
Re: Actuator?
« Reply #17 on: July 10 2014, 01:50:31 PM »
which is the terminal on the analog block that Bob does not like to use?  Ground or 5v?
Re: Actuator?
« Reply #18 on: July 10 2014, 03:52:41 PM »
Original problem was that the boost signal was jumping all around from 20 psi to 10 on the log that was in the first post. I thought that I may have a waste gate actuator that wasn't holding the boost.  Earl asked if I had the MAP sensor power source spliced into the TPS, which I did.  TPS is now back to its original configuration with no Y harness installed. MAP sensor now has a new source for power
Re: Actuator?
« Reply #19 on: July 10 2014, 03:55:50 PM »
I hope someone else knows because I'm using both.  I hope it's the ground...
Re: Actuator?
« Reply #20 on: July 10 2014, 04:19:11 PM »
I believe Bob does not suggest using the PL grd for anything other than very low current devices
Re: Actuator?
« Reply #21 on: July 10 2014, 10:55:07 PM »
I'll move the ground to the chassis some where
