Author Topic: Actuator?  (Read 7379 times)
Actuator?
« on: July 06 2014, 01:57:46 PM »
Can someone please take a look at this log and confirm my suspicion that the waste gate actuator is not holding.  Boost jumps around quite a bit. Only made a 1st/2nd gear pull and little into third.
HD adjustable actuator, RJC boost controller.  Pull starts at frame 500 or so
« Last Edit: July 06 2014, 02:12:18 PM by good2win22 »
Re: Actuator?
« Reply #1 on: July 07 2014, 01:43:35 AM »
Any chance your MAP and you TPS get power from the same place?     Those twitchy spikes don't even look possible in real world time.
Re: Actuator?
« Reply #2 on: July 07 2014, 08:49:02 AM »
Yes they get power from same place.  MAP is connected to power source at the TPS. How could I route another power source for the MAP?
« Last Edit: July 07 2014, 08:57:25 AM by good2win22 »
Re: Actuator?
« Reply #3 on: July 07 2014, 09:15:40 AM »
Personally I would install a 12v to 5v converter to supply the MAP power under the hood, or take it off the 5V output on the PowerLogger.
Re: Actuator?
« Reply #4 on: July 07 2014, 10:07:47 AM »
I'd rather stay away from the analog block.  Any recommendation s on a 12v to 5v converter?
Re: Actuator?
« Reply #5 on: July 07 2014, 11:59:09 AM »
Why? It would be using the same stable power source as the datalogger reading the sensor... or telling the same lie.
As for the converter, nope.  I would google it if I wasn't using a plug and play harness.
The other option is use the factory MAP sensor power for the factory boost gauge.
Re: Actuator?
« Reply #6 on: July 07 2014, 12:53:10 PM »
Don't want to risk frying the ECM...
I have a digital dash, so no power source.
Seem to be quite a few converters out there and they are reasonably priced.  Anybody ever use one?
Re: Actuator?
« Reply #7 on: July 07 2014, 03:26:14 PM »
Re: Actuator?
« Reply #8 on: July 07 2014, 08:24:15 PM »
That thing looks beefy!
Re: Actuator?
« Reply #9 on: July 07 2014, 09:01:34 PM »
Pick up 5v from ecm or maf. No need to make it complicated
Re: Actuator?
« Reply #10 on: July 08 2014, 01:38:05 AM »
^Yep
If it were my car, I would test my theory that the 5V signal is flakey.   I'd run a wire into one of the AUX inputs on powerlogger and go for a blast.  If the 5V line reads spotty like the outputs of the MAP AND TPS, I'd find the reason for that and fix it.
If it reads stable, there's no need to Rube Goldberg up the works.
A quick and easy test would be to unplug the MAP from piggybacking off the TPS. Log a run and see if the TPS still gets twitchy.  That shouldn't take but a second.
Re: Actuator?
« Reply #11 on: July 08 2014, 08:31:49 AM »
I was thinking the same thing.  Quick and easy to disconnect the piggy back from the TPS and run a temp power/ground wire. I'll try to make another run this evening and throw up the results.  Thanks
Re: Actuator?
« Reply #12 on: July 08 2014, 09:53:17 PM »
Ran a power and ground to the analog block of the power logger.  Run starts at about frame 630.  Boost signal is now steady.  Would someone care to explain?
Re: Actuator?
« Reply #13 on: July 09 2014, 07:03:37 PM »
elaborate on the power and ground you ran to the analog block...   what kind of power and from where?
Re: Actuator?
« Reply #14 on: July 09 2014, 10:24:03 PM »
I disconnected the "T" from the TPS, reconnected the TPS to its original plug. Removed the y harness that ran between TPS and the MAP sensor.  Ran power and ground wire from the power logger block, terminal 6 (5 volts) and 4 (ground), to the grey wire (positive) and black wire (ground) on the MAP sensor.  Checked it all over, 4.98 volts at the MAP sensor, hooked up the computer, checked for signal on power logger with the key on.  Started it up and then went and made the run.
« Last Edit: July 09 2014, 10:28:07 PM by good2win22 »
