Author Topic: What do i need?  (Read 10758 times)
What do i need?
« on: June 29 2014, 02:41:11 PM »
Attempted to put some freon in the car today and found the port to be leaking badly on thr black canister. Do i have to replace whole canister? TIA
Offline Scott87
  • Boost Tube
Re: What do i need?
« Reply #1 on: June 29 2014, 06:32:33 PM »
Make a solution of soapy water. .. The soap-ier the better. .. Put the solution in a small squeeze bottle... soap up all joints and lines with the system running. .. look for the bubbles and you will have a better idea of the extent of your leaks. ..
The leak very well may be a deteriorated o ring or seal. ..
Re: What do i need?
« Reply #2 on: June 29 2014, 11:15:04 PM »
Its leaking AT the port where you fill with freon on the black canister on the passenger side. I was asking do I have to replace the entire canister, or just that nipple portion?  Thanks
Re: What do i need?
« Reply #3 on: June 30 2014, 01:57:07 AM »
It's a schrader valve Phil. Replace it with the right one and you may be able to do nothing else.
Re: What do i need?
« Reply #4 on: June 30 2014, 07:27:15 AM »
Thanks
Re: What do i need?
« Reply #5 on: June 30 2014, 12:42:54 PM »
It's a difference between just replacing the stem vs the whole valve isn't it?
Re: What do i need?
« Reply #6 on: June 30 2014, 12:43:48 PM »
Only asking because I found a tool that allows you to replace the stem without losing refrigerant, but I'm not 100% sure if it'll fit my car or not
Re: What do i need?
« Reply #7 on: June 30 2014, 01:24:22 PM »
Nevermind.  Thanks
