Author Topic: Valve covers?  (Read 2639 times)
Valve covers?
« on: June 23 2014, 05:29:48 PM »
Wondering if anyone knows who makes these valve covers?
Offline 1KWIKSIX
Re: Valve covers?
« Reply #1 on: June 23 2014, 06:15:33 PM »
Looks like my M&A valve covers.......e xcept mine are black......the y have a flat bottom sealing surface (no indent / shouldered) area like the stockers do.  I had to RTV the valve cover gaskets to the valve covers.
They are old school  :powersix: , but I like em!  :cool;
These are not ATR Valve covers as the file indicates, they are M&A's
« Last Edit: June 24 2014, 01:05:30 PM by 1KWIKSIX »
Re: Valve covers?
« Reply #2 on: June 23 2014, 06:23:54 PM »
Thanks!  Do you know if anyone still sells them?
Offline 1KWIKSIX
Re: M/A Valve covers?
« Reply #3 on: June 23 2014, 07:31:40 PM »
They're no longer in business as I understand it.  You'll have to post in the wanted sections of all the boards & hope someone has a set their willing to part with.
Think that TA Performance may have bought them out many years ago, but not 100% sure.
TA have some similar Valve covers though.
Even ATR had some that looked very close to the M&A's.
You'll have to hunt around for some used ones no matter what .
Good Luck.
dave
« Last Edit: June 24 2014, 01:05:56 PM by 1KWIKSIX »
Re: Valve covers?
« Reply #4 on: June 24 2014, 08:50:30 AM »
So we should take yours and do some sand casting and a bit of machining...
until someone rats us out for logo infringement LOL
AJ has some of this relationship archived:
http://www.ajlc.waterloo.on.ca/gnttype/200204/785
AJ- any index of any sort?
« Last Edit: June 24 2014, 08:55:30 AM by daveismissing »
Re: Valve covers?
« Reply #5 on: June 24 2014, 09:31:28 PM »
Pretty sure that style of head got shut down due to the logos.
Odd you should mention doing that though...    I've been working with a foundry and thinking about casting some pretty trick valve covers  (and some not so trick units that would actually be cheap to cast and machine)
