Author Topic: Orange ECM wire  (Read 1777 times)
Orange ECM wire
« on: June 19 2014, 12:21:58 PM »
If I unplug this by the battery can i crank the car over but it wont start? I need to prime new turbo with oil before starting and thought this would work?
Re: Orange ECM wire
« Reply #1 on: June 19 2014, 01:01:25 PM »
Yes, it will not start if you unplug the orange wire
Re: Orange ECM wire
« Reply #2 on: June 19 2014, 02:46:10 PM »
Excellent way to disable the engine - poor man's antitheft too.
Re: Orange ECM wire
« Reply #3 on: June 19 2014, 08:55:16 PM »
Or just disconnect the injector harness and save any settings/memory in your ECM/chip.
Re: Orange ECM wire
« Reply #4 on: June 19 2014, 09:08:54 PM »
Just install the turbo and crank it up...in two seconds it will be supplied with oil.  Being as there is no load on the turbo, and hence, no boost, there is no need to crank the engine over to supply oil to it.  The turbo only works when it is making boost...there is nothing to break in as Paul stated.
