Author Topic: New turbo break-in  (Read 2394 times)
New turbo break-in
« on: June 16 2014, 02:09:41 PM »
Did a search and cant find much on this. Anything recommended here? Thanks
Offline PacecarTA
  • im not a newbie
Re: New turbo break-in
« Reply #1 on: June 16 2014, 02:18:24 PM »
whats to know its a shaft with two bearings that all they ask for is oil ,
 once it has oil and oil is warmed up beat the snot out if
87 GnX'd
87 GN TTop..stock as can b
« Reply #2 on: June 16 2014, 05:35:12 PM »
We broke ours in with an 11.17 pass. :cheers:
« Reply #3 on: June 19 2014, 02:30:14 PM »
This!
