Welcome to IHADAV8.com!
yada yada...I am guessing that 2800-3000 rpm will work better with the turbo you ordered.If your stall rpm is lower the car will be slow off the line until the boost comes up but it will probably be fine from a roll as the rpm will be high enuf to allow the turbo to spool.
Lets just hope what he told me will fix it, will see tonight. Also turbopowered68, in the little driving I have done, very laggy
Looks like a bad map sensor is causing my alky troubles. Can I get a map sensor at an auto parts store? After I replace the map how do I adjust when the alky starts spraying?
Brad, what is this "aggressive mode"? I don't see any mention of it in the 5.7 instructions or on the forum
all I have is the SM for tuning. For as much track time as my car see's I cant justify spending the money for PL. Once i get the alky fixed I can start tuning and see what happens. I might be able to get it working "good enough" as i'm not trying to shave every tenth off I can. I do appreciate all the help you guys have given me
