Author Topic: Pass side mirror glass is loose??  (Read 3226 times)
Offline 1987GN
« on: June 04 2014, 11:10:37 AM »
Its a remote mirror...but loose.   Is there a way to tighten?
Re: Pass side mirror glass is loose??
« Reply #1 on: June 04 2014, 03:34:08 PM »
Stretch the coils out with two pair of pliers. then lace safety wire in the gaps.
Offline 1987GN
« Reply #2 on: June 05 2014, 09:40:58 AM »
Lost me on that one....please explain.
« Reply #3 on: June 05 2014, 12:00:49 PM »
The outer sheath(s) is a coiled wire ( three actually), stretching the coils tightens everything.
Sometimes just adding wiggles helps with friction.
Offline 1987GN
« Reply #4 on: June 05 2014, 02:43:00 PM »
where do I access this?  I the remote end of the cable?
