Author Topic: Greetings from Canada, eh?  (Read 6787 times)
Offline gr8g8
  • Newbie
  • GN n00b
« on: May 21 2014, 03:24:50 PM »
Another Canuck joining this board.  I was told by fellow Ontarians (Dave, Paul, Scoob, etc) that this is the place to be to get some answers...well, I can't wait then!
Re: Greetings from Canada, eh?
« Reply #1 on: May 21 2014, 04:18:03 PM »
Welcome. What kind of answers do you need?
« Reply #2 on: May 21 2014, 07:00:30 PM »
Welcome from the westcoast of Canada!
Offline xpander343
« Reply #3 on: May 21 2014, 07:47:03 PM »
the canadian way is to slowly but surely be everywhere.  Welcome  :cheers:
87 Regal Limited
Offline gr8g8
  • Newbie
  • GN n00b
« Reply #4 on: May 21 2014, 09:36:49 PM »
My car bucks under light throttle in OD or when the engine is under load.  I was hoping to send my PL logs for someone to have a look at.  These are the items that have been swapped out to try and isolate the problem:
- new ECM
- new ignition module AND coil pack
- new ignition wires
- cam sensor cap is Caspers LED type
- cam sensor is stock
Thank you,
Angelo
« Reply #5 on: May 21 2014, 11:22:02 PM »
Fuel filter been changed recently?
« Reply #6 on: May 21 2014, 11:24:49 PM »
Attach the logs here. Have you verified the fuel pressure is correct?
Steve
Offline gr8g8
  • Newbie
  • GN n00b
« Reply #7 on: May 22 2014, 06:31:11 AM »
Offline gr8g8
  • Newbie
  • GN n00b
« Reply #8 on: May 22 2014, 06:36:05 AM »
Steve
Hi Steve - FP rises with throttle input  - checked with windshield mounted FP gauge. Fuel filter is relatively new, but could check again.  Could it be any of these?
 - cam sensor faulty
- incorrect gap on plugs? incorrect plugs?
Next step is to replace plugs with RTS44's and gap them at a tight .30 (as per Scoobum's recommendation).  I don't think this is it because I had E3's in it before these plugs and the bucking was there.
Offline tb3
« Reply #9 on: May 22 2014, 08:35:44 AM »
welcome  :cheers:
« Reply #10 on: May 22 2014, 10:51:00 AM »
I'm not sure of your mods but I've had good luck with the ac ones you mention and autolite 26 in my fairly stock car. I usually hit em with .035 but if scoboom uses .030 I'd say go with that as your climate is different. Have you at least pulled em to see what they are gapped at and what they look like? Could be a carboned up one or an oily one.
