Author Topic: Question about front tires  (Read 9458 times)
Offline deathraider6996
  • PSI: -1
« on: May 06 2014, 10:16:40 AM »
What would be a good size tire for a stock wheel/stock height car. I will have 275/60-15 Mickey Thompson  in the rear. I really don't care about matching front and rear brands. 50/50 street/strip. Not looking to spend booku money. Thanks in advance.
Sent while curing depression with boost.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
Re: Question about front tires
« Reply #1 on: May 06 2014, 12:48:17 PM »
Stock 15x7s? 215/65R15.
« Reply #3 on: May 06 2014, 05:37:38 PM »
I've found a thinner tire will push through the beams fairly easy. I run a 235/60/15 on the front.
« Reply #4 on: May 06 2014, 06:09:24 PM »
If you want to try the thinnest of thin, try my 165/80R15's rims and tires. Doesn't meet your requirements of stock rims though. They are yours to borrow if you want. :rock:
« Reply #5 on: May 07 2014, 10:01:23 AM »
I use a 215/70-15, as I couldnt find a 215/75-15 in stock anywhere when I was needing a pair. I have a hydroboost and don't have too much trouble with 5-7 psi launches. If you need more I think you need a trans brake.
Oh, they are on a stock T wheel. Even I'd d kirban doesn't like the look I think they are cool. Throw back to the Dukes of Hazzard Charger wheels I guess.
