Believe it is 6-10 thousandths...Gary's probably the best advice. It's too tight, so a tooth contact pattern should tell you which way the ring gear needs to move which will entail pulling a shim(s) on one side or the other. There should be a good tutorial online how to know what to do....If this is an used rear end-hopefully you can avoid worrying about the pinion depth and just concentrate on moving the ring gear side to side....
I thought doing a tooth-contact test was mandatory when rebuilding a diff?
