I have a delta gate that everyone says sucks instead of blows. Lowest boost I can get is 14psi but I can easily go up to 30psi. And it stays at exactly where I put it at with no spiking. You're hooking it up in boost sensing mode. I basically set mine up so I have a low pressure side on the wastegate and a high pressure side. I don't connect to the boost sensing port on the turbo. I have a high pressure side and low pressure side connected to my controller. I don't vent one side of the controller. Working with differential pressure cells I thought this method would work much better and it definitely does. Diagram picture on paper by chance, I'm not sure I follow, my fault as I am new to this stuff. Thanks
