Author Topic: Engine Build  (Read 6752 times)
Re: Engine Build
« Reply #15 on: May 02 2014, 02:55:08 PM »
I will ask Jamie he is very particular he had all my fasteners they were brand new ARP, he even used studs to hold the heads on when he did the line bore since that's what I will be using he said that there can be a difference with head bolts compared to studs  plus he won't use a torque plate its gotta be heads when doing a line bore
« Last Edit: May 02 2014, 03:00:11 PM by larrym »
Re: Engine Build
« Reply #16 on: May 03 2014, 04:26:51 PM »
all finished up oiled and bagged.
Bearings are all.0018-.002
Thrust .004-005
pistons finished at .004 inside the hole.
now all I have to do is hurt the motor in it! :rock:
Re: Engine Build
« Reply #17 on: May 03 2014, 09:32:27 PM »
Lookin' good!
Re: Engine Build
« Reply #18 on: May 05 2014, 02:51:28 PM »
Sexy pistons..  :player:
