no spark on 84 GN
Pages:
2
Topic: no spark on 84 GN (Read 6750 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Re: no spark on 84 GN
Reply #15 on:
March 24 2014, 06:44:02 PM »
ok==== I have no injector pulse,
Reply #16 on:
March 24 2014, 07:16:24 PM »
that would take you to crank sensor given you have done the module....with a big assumption that the wires show continuity end to end
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #17 on:
March 24 2014, 08:00:07 PM »
bad thing is on the 85 the crank sensor is hard wired into the sensor. when I was running the test, the sensor was showing good IDK
Reply #18 on:
March 24 2014, 08:13:19 PM »
not sure what you mean by hard wired, but that is okay...I don't wanta know anything about a hot air car....
Does it have a double slot like the ic cars where it can be installed incorrectly?
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #19 on:
March 24 2014, 08:15:24 PM »
I think so, I will check on it tomorrow.
Reply #20 on:
March 24 2014, 08:24:32 PM »
looking at C4B on the 85 tree, seems like it could aim at the crank sensor as well...
tb3
PSI: 2
Reply #21 on:
March 25 2014, 02:00:12 PM »
earlier crank sensors had the plug molded into the bracket. later ones had wires coming off it and then the plug
Reply #22 on:
March 25 2014, 05:32:17 PM »
still looks like it needs a new crank sensor to me...
Pages:
2
no spark on 84 GN
