Author Topic: Classic Fast (sequential) & Wide Band  (Read 2623 times)
Offline ttipe
« on: February 24 2014, 08:51:54 PM »
This kit has everything except the thread in port for map.It is plug and go. It has a 95lb flash on board. Hartline will provide support for low cost but buyer needs to call Holley. My work has kept me busy so I've had little time to play. I have an XFI ready so I'm not forced to sell. I'm looking at trades (I could use a proper rad rebuild with engine & trans coolers and appropriate fittings and a transmission upgrade). The harnesses are in great shape. Comes with NTK wide band and 3 bar map. I won't go lower than $750 (its in great shape) and buyer pays the freight.
Thanks for looking
Re: Classic Fast (sequential) & Wide Band
« Reply #1 on: May 20 2014, 08:26:10 AM »
Bump
