Rear sway bar adjustment
Topic: Rear sway bar adjustment (Read 3174 times)
trashmechlv
Turbo Street Limited
February 23 2014, 03:20:47 PM »
Any advice on properly setting up for drag strip? I have Hellwig rear bar set on firmest setting. Should it be set with any preload or neutral on the end links with tires on ground? I also have Spohn solid LCAs. Maybe somebody has a good link for setting up? Thanks
Mike G
Re: Rear sway bar adjustment
February 23 2014, 03:56:23 PM »
At your level, you should not need preload...set it up neutral and if it launches straight, leave it alone
trashmechlv
February 23 2014, 04:52:08 PM »
Thanks. On street car night our track does no prep and traction goes down hill fast. Just trying to optimize what I have. Will try to make some passes in 3 weeks.
Mike G
February 23 2014, 05:45:25 PM »
if it lays down two even stripes the same length, it is good to go
Scoobum
February 24 2014, 03:47:17 PM »
Low 1.6 launches here with an old skool ATR rear bar and cheapie Lakewood 70/30 fronts and 50/50 rears.
trashmechlv
Reply #5 on:
February 24 2014, 08:32:34 PM »
Nice Scoobum. I have cut some low 1.70s and then next pass spin tires and cut 1.9x. Im running my Hoosier drag radials at 19psi when warm. Maybe I will drop psi a little more next time out. Have another street car night in 3 weeks. At the end of April a group of turbo Buicks are going to hit a real TnT with a prepped track.
Mike G
