Welcome to IHADAV8.com!
I would tell you great minds think alike, but, I am getting more feeble minded each day, I think
I don't believe it is the regulator or the pump....sounds like something electrical. If you wiggle each injector harness connector, does it cut out while wiggling? No ChangeWhen you are adjusting the iac, take it all the way down to zero and see if it acts up then Not tested?does it do it at higher rpm? Not answered
after pulling the vacume line off the reg and it stumbled but pressure did not move i felt it was not the pump or reg
