Author Topic: new PLs  (Read 2266 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
new PLs
« on: February 16 2014, 09:30:59 PM »
three passes today , after changing the rearend oil , and installing air bags. ran 7psi in left and 14 in right. time slips are in order and also the logs.
Re: new PLs
« Reply #1 on: February 17 2014, 01:22:51 AM »
Fueling looks much better to me..might still be a tad rich, but, I don't think it will go any faster if you lean it further and since you are not a pro racer, I would leave it alone now that you pulled all that excess out.
Still need to find out if the voltage is really 12.9 or is that the usual scantoool deception
As I always harp...taller tires and a bigger turbo would kick it in the tail....but you ain't gonna get outrun very often by anything that can be driven on the street routinely so I would be pretty happy with it :)
Re: new PLs
« Reply #2 on: February 17 2014, 03:52:29 AM »
You're getting all kinds of KR in high gear.
