Author Topic: Ball Joint Help  (Read 8037 times)
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
Ball Joint Help
« on: February 14 2014, 04:42:52 PM »
So my question is.
How do I press in the upper control arm ball joints? Do I just hammer the sleeve in and then slide the ball joint in and tighten it? I assume that if I hit the sleeve in through the hole it will bend the metal?
Or am I going about this all wrong and the sleeve is on the bottom and you just slide the ball joint through the hole and button it up?
Sorry If I'm using the wrong terms.
Stratman: Is it even running?
Offline 1KWIKSIX
Re: Ball Joint Help
« Reply #1 on: February 14 2014, 05:04:01 PM »
Hey Justin,
I'm pretty sure the upper ball joints are simply bolted into the control arm….the lower ball joints are pressed in. At least that's how my stock front control arms were.
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
Re: Ball Joint Help
« Reply #2 on: February 14 2014, 06:20:10 PM »
So out of these two images what is the correct way of bolting them in place?
Re: Ball Joint Help
« Reply #3 on: February 14 2014, 06:42:50 PM »
I assumed the uppers were riveted in from the factory...and you simply knocked off the rivets and bolted the new ones in through the rivet holes. The lowers are a press fit.
Re: Ball Joint Help
« Reply #4 on: February 14 2014, 06:49:09 PM »
First things first. How were the old ones attached?
Re: Ball Joint Help
« Reply #5 on: February 14 2014, 06:59:36 PM »
Stockers are riveted in place.   It's a bolt in deal. The last one I did on my Blazer (same arm) was a Moog and came with bolts that I didn't really like.  I ended up getting some nuts 'n bolts I trusted better.
Offline PacecarTA
  • im not a newbie
Re: Ball Joint Help
« Reply #6 on: February 14 2014, 07:51:05 PM »
top pic ...just tap it
87 GnX'd
87 GN TTop..stock as can b
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
Re: Ball Joint Help
« Reply #7 on: February 14 2014, 07:54:06 PM »
Thanks that's what I assumed as well. Just wanted to make sure. From the factory they are riveted , my AC Delco pack has provided the hard wear and they should hold up.
Offline PacecarTA
  • im not a newbie
Re: Ball Joint Help
« Reply #8 on: February 14 2014, 08:02:57 PM »
87 GnX'd
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
Re: Ball Joint Help
« Reply #9 on: February 14 2014, 09:02:22 PM »
Good find.
Re: Ball Joint Help
« Reply #10 on: February 15 2014, 01:07:35 AM »
Ball joint on top and con arm on bottom. that way if the bolts come loose (God forbid) the knuckle won't flop and cause you to wreck.
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
Re: Ball Joint Help
« Reply #11 on: February 15 2014, 01:39:50 AM »
Finished product
Re: Ball Joint Help
« Reply #12 on: February 15 2014, 05:59:49 PM »
Well done!
Re: Ball Joint Help
« Reply #13 on: February 16 2014, 09:35:51 AM »
OMG!!!!!!!!!!!!!!!!!  SuperSix posted on his own board!!!!!!!!!!!!!!!!!!!!!
