Author Topic: Looking for a Good used or new Belt Tensioner  (Read 4339 times)
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« on: January 15 2014, 06:25:21 PM »
PM me if you have a good belt tensioner or a new tensioner.
Thanks, Justin :rock:
Stratman: Is it even running?
Offline gnonyx
Re: Looking for a Good used or new Belt Tensioner
« Reply #1 on: January 16 2014, 06:44:17 PM »
That is some tall order being the belt tensioner has been discontinued from GM
If you don't get a reply from this board you might not has a choice but to get it a belt tensioner from one of the Buick Vendor, and pay their price.
http://www.nos4gn.com/servlet/the-271/buick-grand-national-25526387/Detail
http://www.gbodyparts.com/product_info.php?products_id=312
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« Reply #2 on: January 17 2014, 05:26:32 PM »
I've been dreading paying the price of a new one... haha I could buy much need parts for what seems to be a 80 dollar part for almost 400 dollars with shipping.  :013:
« Reply #3 on: January 17 2014, 07:10:12 PM »
I guess our 30k or so production isn't enough to warrant an after market mfg to step up and produce a replacement.
I deliver to a place that makes aluminum castings and was thinking I should ask about a small run of castings to make them but I doubt I could bankroll such an undertaking.
What generally goes bad with the tensioner? Does the spring break or the casting have a problem?
Another thought I had was if the spring breaks one could disassemble and replace the spring.
Anyone have thoughts?
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« Reply #4 on: January 19 2014, 04:14:27 PM »
I find that the aluminum cracks at the mounting bolt holes due to torque straps and then vibrates once broken. The fix to this is do not use a strap and if you are making real power invest in poly mounts or get the RJC brace. I'm guessing the spring can give out but I'm positive you can fix that by buying a 1 inch shorter belt to stop it from clacking. In my Case my mounting bolthole is busted off.
