Author Topic: wtb set of stock fuel injector clips & tb coolant lines  (Read 11632 times)
Offline tb3
« on: January 02 2014, 12:19:25 AM »
needing a set of both the clips that hold the fuel injector to the rail, and, the wire springy clips that hold the wire harness plug onto the fuel injector.
if you don't have a complete set of 6 each, I need at least 4 of the clips that hold the injector to the rail, and 5 of the clips that hold the plug to the injector.
I'm also needing the 2 molded coolant lines that run to the throttle body.
I know this is small $$$ but hopefully one of y'alls won't mind going through your stuff and helping me out   :cheers:
Re: wtb set of stock fuel injector clips & tb coolant lines
« Reply #1 on: January 02 2014, 09:54:34 AM »
wonder how many of those damn injector clips I have thrown away?
Offline tb3
« Reply #2 on: January 02 2014, 11:29:37 AM »
I went through my misc jar awhile back and gave my spares away to help somebody else out.
I just took a peek at my 04 lesabre and the clips for the rail are the same and available everywhere.
but the wire clips are differant.  I may have to hit a yard for a first generation 3800 motor.
I'm still convinced I've got some laying around somewhere
Offline tb3
« Reply #3 on: January 02 2014, 11:31:57 AM »
Caspers surely has some,  if I can convince him to sell just the clips and not the whole plug
« Reply #4 on: January 02 2014, 03:45:06 PM »
Thought I probably had an extra harness in the shop but I musta thrown it away recently
You can probably go buy a connector in the HELP section and pull the clip off
Offline tb3
« Reply #5 on: January 02 2014, 10:39:58 PM »
found some in a jar of bolts. :rock:
I knew I wouldnt find any unless I jinxed myself with this thread.  Im all good to go  :cheers:
