Author Topic: winter storage...alky  (Read 2245 times)
« on: December 18 2013, 04:52:28 PM »
Do you guys in cold climates empty your alky systems and replace with anti-freeze windshield wiper fluid? I was told to do this, and did, but I dont understand the benefit??
Offline PacecarTA
  • im not a newbie
Re: winter storage...alky
« Reply #1 on: December 18 2013, 05:15:24 PM »
alky cant freeze
windshield washer fluid is hit or miss on if it will freeze
if you arent going to use for a while , just drain it. either pull the hose off at the pump or  take the hose off nozzle and put in a bucket ,unplug the map sensor and put a wire across the map sensor gray and green wire and turn it on (or hold the test button) ,  the pump will run and empty the system
i personally dont do a thing except make sure there is alky in the tank  and it makes pressure before boosting it
87 GnX'd
87 GN TTop..stock as can b
« Reply #2 on: December 18 2013, 11:28:09 PM »
 :cheers:
« Reply #3 on: December 19 2013, 12:28:23 PM »
fill it with single malt and call it a day!
oops thats me not my car  :P
