its not the regulator , its the return line cant flow back what the hotwired walbro is supplying im sure if you bypass the hotwire at the tank by plugging the pump back into the factory harness youll see the pressure drops try opening up the return line ends (the opening of the saginaw ends) with an awl or a small drill bit , and check the line at the axle and tank for kinks
If you installed one of the higher output pumps like the TT pump that Eric sells, then it may not be large enuf.
