Author Topic: Comp Valve Spring Question  (Read 6045 times)
Re: Comp Valve Spring Question
« Reply #15 on: November 17 2013, 08:33:06 AM »
You really need to consult with your machinist as to what his recommendation is for valve spring pressure. Boost pressure, cam selection and RPM's are a big factor in determining what you need.
« Reply #16 on: November 17 2013, 09:29:54 AM »
that is good advice-particularly if one is using an aftermarket cam.  I would suspect a lot of machinists may not be familiar with these engines and turbo cars in general so I would tend to start with what the cam manufacturer suggests.
In this case, we know what we are dealing with so the comp 980's, or the equivalent, is the tried and true spring that will allow the engine to rev to 5300, or a bit more, without undue wear on the lobes and they should provide a bit longer life.
It is seldom mentioned, but Brad just did above, boost in the intake will try to hold the valve open when it should be closing and if one figures the psi on the back of the valve, this can really make an old set of springs struggle which is the reason we see engines go flat on power in the lower 4000 rpm bands so often
