NA 109
2
Topic: NA 109 (Read 5895 times)
larrym
PSI: 1
NA 109
November 11 2013, 07:13:28 PM »
Just picked up a 109 out of a 87 cutlass, stripped it down to a bare block.
Found 2 dot rods, all the pistons pushed out the top NP. bearings showed some wear as do the cylinder walls.
What else is worth saving other than the heads, rods and front cover?
Last Edit: November 11 2013, 07:36:30 PM by larrym
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Re: NA 109
November 11 2013, 08:00:24 PM »
four barrel intake?
earlbrown
PSI: 6
Re: NA 109
November 11 2013, 09:33:21 PM »
See if the crank is the more desirable 'turbo' crank.
larrym
PSI: 1
Re: NA 109
November 11 2013, 11:56:48 PM »
It's a 2 barrel and no rolled fillets.
earlbrown
PSI: 6
Re: NA 109
November 12 2013, 01:05:31 AM »
Pretty much block, rods and misc fasteners. The rods are supposed to have lesser bolts in them, but I've never heard of one coming apart without the factor SPS units though.
larrym
PSI: 1
Re: NA 109
Reply #5 on:
November 12 2013, 02:17:59 PM »
Is the oil pick up the same?
I see no baffle in the pan
Charlief1
Just another kinky six
PSI: 2
Re: NA 109
Reply #6 on:
November 12 2013, 02:51:26 PM »
Pick up is the same and you can weld a baffle in the pan.
larrym
PSI: 1
Re: NA 109
Reply #7 on:
November 12 2013, 07:16:30 PM »
Lol!
You would not be saying that Charlie if you had seen any of my welding job!!!!
earlbrown
PSI: 6
Re: NA 109
Reply #8 on:
November 12 2013, 07:55:49 PM »
I've heard it's pretty easy to make a baffle out of a VCR case. You can even see the 'Y' from 'SONY' on my pan. lol
Charlief1
PSI: 2
Re: NA 109
Reply #9 on:
November 12 2013, 09:02:35 PM »
Now I know what I can use the broken ones I'm about to throw away Earl.
earlbrown
PSI: 6
Re: NA 109
Reply #10 on:
November 13 2013, 01:34:12 AM »
You've seen it before...
http://www.turbobuicks.com/forums/buick-v6-turbo-tech/88129-day-life-earl-2.html#post788883
I wasn't kidding about the ''Y'
larrym
PSI: 1
Re: NA 109
Reply #11 on:
November 14 2013, 01:13:58 PM »
Is the balancer of any use? Could it be used on an internally balanced crank?
earlbrown
PSI: 6
Re: NA 109
Reply #12 on:
November 14 2013, 01:16:51 PM »
Does it have the fins on the back to trigger a crank sensor?
Charlief1
PSI: 2
Re: NA 109
Reply #13 on:
November 14 2013, 01:21:08 PM »
If it was a injected engine then it would have the trigger on it. If it doesn't then it would work for any NA or 83 and earlier turbo Buick. It can be made into a neutral balance but will need the trigger put on it.
larrym
PSI: 1
Re: NA 109
Reply #14 on:
November 14 2013, 02:52:28 PM »
Thanks gents I was talking to a buddy he just picked up a internally balanced crank he might try to use it is there any advantage to a trigger with more fins? would that not just confuse the ECU?
2
NA 109
