Author Topic: wb 02 and knock  (Read 2311 times)
Offline Jeff
  • The Thread Killer....
wb 02 and knock
« on: November 05 2013, 11:44:14 PM »
Well it seems every new part I add knocks seems to come with it. The parts im.adding are only for monitoring- pl wb02... I finally got wb02 installed-plx and on one run I hit 14#s but wb.was showing 12.49. Does it matter the car wasnt floored and tps volt was about 2. I guess im.asking even though it wasnt floored it showed 12.49. I did.also.exper ience a 5.8kr at this.point... oh the 02s were 799 when.all tbis happened.
 Another queation am I analyzing this.right? Looking at tps volts w 02 w wb?
Re: wb 02 and knock
« Reply #1 on: November 05 2013, 11:57:05 PM »
yes, it can matter...if the tps voltage is low and the lv8 is low, then the chip may not be adding the fuel required to handle the boost.  You are not the first that want to tune for boost at part throttle but my prior rants never seem to have any effect.  :)
Offline Jeff
Re: wb 02 and knock
« Reply #2 on: November 06 2013, 12:32:31 AM »
Thx  for reply Steve.  Unfortunately wot pulls are a little hard in my neck.of the woods. I figured if the cars not tuned for part throttle then why go.wot. im just looking to baseline the car maksure its running as it should. Ill try for a wot pull.soon..
