An alky kit?
So it sounds like I need to turn up the boost in order to maximize what I already have as opposed to installing a new IC. Apears as though the safest way to do that is to run alky??
...Steve the Hemco arrived today.Thanks so much. There is a lot to be learned.
Joel I'm nearly finished a pump gas motor with a few little twists. The secret to a pump gas engine is reducing heat, burn efficient and be cautious with spark. A pump gas engine that hauls is a little more interesting to do with the original LC2 cylinder heads.If your combo is listed correctly it appears like you are short on fuel pump volume.
... and be cautious with spark. ...
