Author Topic: Hemco Upper  (Read 14783 times)
Re: Hemco Upper
« Reply #30 on: October 29 2013, 09:52:34 PM »
could well be.  it should be there tomorrow but I never believe the PO anymore :)
Offline ttipe
Re: Hemco Upper
« Reply #31 on: October 29 2013, 10:09:01 PM »
I updated my combo in my profile.
Offline ttipe
Re: Hemco Upper
« Reply #32 on: November 22 2013, 11:31:51 PM »
Interesting stuff going on. There is a post on the "other board" I believe in the general section titled "interesting numbers". Richard Clark was flowing different intake manifold / plenum combos. They were using some science in their approach. They flowed a Hemco and it did very well. I don't know whether you venture over there or not but the results are very interesting, not conclusive but some ideas are coming to light. I'll chime in tomorrow with specifics that I thought after you have had an opportunity to see for yourself.
Re: Hemco Upper
« Reply #33 on: November 22 2013, 11:38:05 PM »
no, I never bother going over there ;)
Re: Hemco Upper
« Reply #34 on: November 23 2013, 10:48:02 AM »
Found them....looks like the PP does what it is supposed to and would be good on the average car.   The Hemco flows a bit more and also does a good job.  Given the upside on really fast cars, someone needs to start casting them again :)
More interesting to me was the upside potential of the intakes themselves-again for really fast cars
Offline ttipe
Re: Hemco Upper
« Reply #35 on: November 23 2013, 05:06:53 PM »
There is a 9 cfm gap between 2 & 4. If I can reduce that gap by 4/5 cfm that will make my day (based on their testing). I asked if they flowed it with the egr tower in/out. If the tower was in that could fix my concern.
Offline ttipe
Re: Hemco Upper
« Reply #36 on: February 24 2014, 08:59:14 PM »
Hemco being gently worked. Lower being equalized. I did play around with all these findings from Richard Clark and #2 needs flow improvement. Do I believe my findings. No Way! Too much variability with the work of others. The proper way is to balance the manifolds (upper & lower ) as a system. Lots of data and long story. For building a pump gas only car equalizing the intake is definately a plus.
Re: Hemco Upper
« Reply #37 on: February 25 2014, 09:07:42 AM »
some times, one must find the answer and then create the theory
Re: Hemco Upper
« Reply #38 on: February 25 2014, 06:17:59 PM »
Sounds like you found hardcore religion!  :D
Re: Hemco Upper
« Reply #39 on: February 25 2014, 07:50:05 PM »
I cannot argue against that
