Author Topic: data logs from test and tune 10-20-13  (Read 10031 times)
Re: data logs from test and tune 10-20-13
« Reply #30 on: October 30 2013, 09:19:27 PM »
before you do that...run a power feed straight to the back of the car and put power to the pump directly
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #31 on: October 31 2013, 02:16:07 PM »
I have the racetronix hot wire kit , I had my son under the car last night checking voltage, there was 8v on one wire for 3 seconds when key was turned on, I dont know which wire it was. there is a black , purple, and red . I am assuming that the black is ground and red for sending unit and purple for pump.
« Reply #32 on: October 31 2013, 03:32:27 PM »
I am guessing your assumptions might be wrong-I don't have a racetronix hot wire...but it matters not....8 volts will not cut it
Once again, I suggest you apply power from the battery straight to the tan wire that goes to the pump in the factory original harness from the pump
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #33 on: October 31 2013, 05:58:27 PM »
got under the car to run straight power , and I see the problem, I had smashed the hot wire kit power wire in the bolt the holds the tank strap, burnt fuse, gotta love working in the dark. thanks Steve for being patient  :rock:
« Reply #34 on: October 31 2013, 06:26:45 PM »
when you get as old as me, patience is a necessity even if not a virtue...
I almost dropped the tank on one of mine recently until I convinced myself to check everything out first....
