Author Topic: Moser Axles-When?  (Read 9933 times)
Moser Axles-When?
« on: October 13 2013, 05:57:45 PM »
At what short time is it good to go with Moser axles? I normally pull low 1.6's...is it time?
Re: Moser Axles-When?
« Reply #1 on: October 13 2013, 07:42:20 PM »
I think so
« Reply #2 on: October 13 2013, 07:50:42 PM »
be nice if you could hold out until you need a new posi...then you could upgrade to 30 splines with a matching posi
« Reply #3 on: October 13 2013, 08:02:56 PM »
Do you have a girdle?  What does your car weigh?  My car weighs in at 4050lb with me in it.  I pulled a 1.61 60ft three times then snapped the axle on the next pass and this was still with the stock converter, unopen motor with only a TE-44.  I upgraded to 30 spline, but if I were you play it safe and get some better axles.
« Reply #4 on: October 13 2013, 08:21:06 PM »
Moser girdle...Aubur n Pro Series Posi. Never weighed the car...but it's a T Top power everything with the following weight reduction: Air con delete,,,but retains the heater box...RJC lower race pulley...9.5" NL convertor...al uminum driveshaft...a luminum rear drums...sound deadener removed...LT1 starter...F Body rad conversion...a luminum front and rear bumper inners...and the driver weighs 170...the oil cooler lines and adaptor were tossed in Lake Ontario...the IC fan is used as a Frisbee at the shop...someone please do the math.
« Last Edit: October 13 2013, 08:27:39 PM by Scoobum »
« Reply #5 on: October 13 2013, 09:56:51 PM »
Are you good at body work? Have you seen what a broke axle does to a quarter panel as it exits the housing?
Put em in. Just not worth the hassle of breaking one to find their limits.
« Reply #6 on: October 13 2013, 11:52:07 PM »
That does not happen when you weld ford axle tube ends on the housing
« Reply #7 on: October 14 2013, 09:37:41 AM »
Or when you convert to disk brakes...
Offline bescurred
« Reply #8 on: October 18 2013, 05:05:11 PM »
You have a TR that weighs 4050 with you in it?
« Reply #9 on: October 19 2013, 10:01:49 AM »
That is not all that unusual.
Offline bescurred
« Reply #10 on: October 19 2013, 02:27:52 PM »
Hmmmm I weighed my full weight 86 hardtop GN with me in it was 3650ish...that's crazy that there could be 400 pounds difference!
« Reply #11 on: October 19 2013, 06:56:34 PM »
The reason it weighs so much is because of all the extras I have in it.  I told my buddy who own's a Stage II car, how much it weighed and he said, "No way!"  Then I opened my trunk for him and he then said,  "Yeah, possibly."  Car weighed 3800lbs when I put it on the scale.  I have T-Tops, the concert sound system with 10 after market speakers, 4 subs, 5 amps, and an electronic crossover, 10 disc exchanger.  Car also has carpeted trunk kit.  And when I race I couldn't be bothered with removing anything, not even the spare.
« Reply #12 on: October 19 2013, 08:12:55 PM »
those damn cross overs do it every time
« Reply #13 on: October 19 2013, 08:32:55 PM »
fuzzy dice?
« Reply #14 on: October 20 2013, 03:25:01 AM »
fuzzy dice?
No, they don't weigh enough.  I have solid gold dice with diamonds. :rock:
