Author Topic: Dynommax bullets on a tr?  (Read 5339 times)
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« on: October 10 2013, 12:28:21 PM »
Dose anyone have them? If so care to post a video?
Stratman: Is it even running?
Offline Grumpy
Re: Dynommax bullets on a tr?
« Reply #1 on: October 10 2013, 02:22:28 PM »
we used them in place of a cat.. didn't do a hell of a lot.
« Reply #2 on: October 10 2013, 03:20:58 PM »
I've got a dynomax race magnum on a 3" single shot. Didn't really quiet it down any but it did take away some whistle.
If I ever have to get under there and play with it, I'll be running a straight pipe and getting all the whistle back.
« Reply #4 on: October 10 2013, 04:19:22 PM »
I'm not even clever enough to figure out what that is...........
« Reply #5 on: October 10 2013, 05:25:10 PM »
It's a resonation chamber named after Mr. Helmholtz  :)
« Reply #6 on: October 10 2013, 07:00:37 PM »
Hows those valve springs comin' along?
Offline 278CIKILLER
« Reply #7 on: October 10 2013, 07:05:50 PM »
I got some used Hooker Mufflers for sale.
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« Reply #8 on: October 10 2013, 10:13:52 PM »
Brad there still in the box awaiting installation. No thanks Dan I want the bullets.
« Reply #9 on: October 11 2013, 12:17:16 AM »
Whatever you do don't use two chambers tuned slightly differently.
Dr Bose will threaten to sue you with  all his expensive lawyers.
Offline Grumpy
« Reply #10 on: October 11 2013, 09:43:24 AM »
I have a set here if someone is interested. Def quiet the car down.
« Reply #11 on: October 11 2013, 02:22:44 PM »
There goes my dream of making an 400 foot long exhaust system stuffed under my car.
