Author Topic: Wnt to track last week...  (Read 3929 times)
Offline 1987GN
« on: October 04 2013, 09:45:54 AM »
11.60 @ 119 ....My 60ft. time needs work at 1.7.... Once i hit 6lbs brake boosting, I start to push through the beams....
Re: Wnt to track last week...
« Reply #1 on: October 04 2013, 12:32:47 PM »
NICE, more info...set up, tires, temps...
« Reply #2 on: October 06 2013, 06:34:05 PM »
That's a decent time!  As mentioned, what are you running and what timing, boost, etc?
« Reply #3 on: October 06 2013, 07:43:34 PM »
Nice MPH
« Reply #4 on: October 06 2013, 08:04:29 PM »
Great MPH
« Reply #5 on: October 06 2013, 08:11:06 PM »
X3 on the mph!
Offline 1987GN
« Reply #6 on: October 07 2013, 10:18:19 AM »
Thanks Folks...
I have a forged bottom end, 212/212 cam, ported Irons / larger valves, ported intake, 6262 Precision, 9/11 converter, 275 Nittos..
Just a street cruiser :)
« Reply #7 on: October 07 2013, 04:25:55 PM »
The CEA 6262 with supporting mods is a legitimate 10 second turbo. What was your 1/8th MPH and ET?
« Reply #8 on: October 07 2013, 07:47:18 PM »
Thanks Folks...
What about timing and boost?
